1 - 2 of 2 Posts
BMR Suspension Releases New Product
5[SUP]th[/SUP] Gen Camaro/S197 Mustang/4[SUP]th[/SUP] Gen Camaro Solid Motor Mount Upgrade Kit
MM006 $49.95
Eliminate engine movement and maximize throttle response in your 2010-Up Camaro, S197 Mustang, or 4[SUP]th[/SUP] Gen Camaro with a Solid Motor Mount Upgrade Kit from BMR Suspension. These motor mount bushings are constructed from 6061 billet aluminum and are designed for max-effort performance applications. The BMR Solid Motor Mount Upgrade Kit (PN MM006) eliminates engine movement by replacing the polyurethane bushings from the MM004 motor mounts, all BMR S197 Mustang K-members, and the KM005 and KM019 Camaro K-members. Installation time is 2-3 hours with stock exhaust manifolds (install time may be longer with aftermarket headers). Available in black anodized finish.
To preview all of BMR's high-performance suspension parts, please visit www.bmrsuspension.com, email [email protected], or contact them at BMR Suspension, 928 Sligh Ave, Seffner, FL 33584, 813-986-9302, Fax: 813-986-8055.
Discussion Starter · #2 ·
Someone brought up a good point/question on another forum....so I figure I would share.
;14326029 said:
Why aren't you recommending a commensurate bushing/mount upgrade at the transmission to go along with this?
I am a big fan of eliminating driveline/train flex at the origination point - which is the Engine.
I am also a big fan of having a softer trans mount, than engine mount.
My reasoning is simple.
-When you have a trans mount that is of higher rigidity - you open up the possibility of damaging the transmission case/bellhousing.
-NVH level increase, is much more pronounced when you upgrade the trans mount (in comparison to the Motor)
These pieces are for our K-Member. If someone has our K-Member, they do not need an upgraded trans mount IMO.
Thanks for the question!
Kelly
1 - 2 of 2 Posts
