1 - 16 of 16 Posts
I'm getting close to getting it back on the street and am thinking about the brake setup.
My track wheels are 15x3 pro stars so I can't go the monster rotor route. Will stock rotors and upgraded pads do the trick or should I go ahead and pick up a set of cross drilled or slotted rotors to help out?
I am the Stig
I dont see why some trick pads and stock brakes won't work. Its hauled my car down from there numerous times. They will work fine, they are cheap and easy to maintain. But not the lightest though.
Crossdrilled/slotted rotors won't help at all bro. Get some better pads that's all you need. You could go larger but then you need spacers for the drag tires.
I found myself in trouble one time on the street, couldn't stop, and I bought the Cobra Front brakes the next day, 10 times better than stock. For the track the stockers are fine. For the street Cobra upgrade brakes all the way. JMO.
I'm still on stock brake system and it stops just fine for me. Certain tracks have a shorter run-off area though, and it gets a little hairier. The 1/4 track down in Jackson, SC is one with a short runway, and it takes all the brakes to haul it back down to make the return road.
I run the brakes an 01 GT came with, stock replacement pads... and 3.5" MT skinnies, never had an issue with our local track. I don't see a 130 or so car having a problem, but I would imagine 140-150, and you better have brakes that stop on a dime.
Discussion Starter · #14 ·
I'm failrly confident of reaching 130 in the 1/4. 140 is not unthinkable though.
I'm prob going to upgrade the pads and fluid and go from there.
I went with slotted rotors, hawk pads and S/S lines all around and it slows the car just as good at 65 as at 125
1 - 16 of 16 Posts
