OK, here are the meat and potatoes. Here is the baseline data from the stock plenum / stock TB. Here are the details on the car:
-2000 GT
- 10# P1sc S/C kit with a 3 core intercooler
- 42# injectors
- Focus pump
- Lightning 90mm MAF
- Bassani cat-back
- MAC off road H-pipe
- My chip
* everything else on the car is stone stock
The testing was done with an average of 10 minutes passing between each run. This was to allow the temperatures stabilize and maintain as much consistency as possible. I started each run with 176 degrees (ECT) showing on the scan tool, and I LOCKED the timing at 14 degrees in the chip as not to skew the results. Notice the correction factors from the runs, they were all damn near identical, I couldn't have done a more fair and honest comparison............period.
Here are the baseline runs, I'll post the results of the C&L Plenum and BBK 75mm TB next:
Dynojet Research Inc.
Dyno Dan
Run Name: U:\Ford\Mustang\2000 GT\C&L Test\Stock Plenum_001.drf
Run Title: C&L Test
Run Notes: baseline test, timing locked at 14 for consistency, no other changes to calibration
Run Date: 9/6/2003 3:37:30 PM
Stock Plenum_001.drf: 95.66 °F, 27.88 in-Hg, SAE: 1.10
s RPM x1000 hp ft-lbs Air/Fuel
0.18 2.20 N/A N/A 12.87
0.73 2.35 129.76 290.00 12.85
1.17 2.50 140.30 294.74 12.85
1.61 2.65 152.09 301.43 13.17
2.04 2.80 164.33 308.25 13.13
2.45 2.95 177.82 316.59 13.06
2.86 3.10 192.37 325.92 13.20
3.24 3.25 212.65 343.65 13.02
3.61 3.40 231.56 357.68 13.04
3.97 3.55 249.69 369.41 12.90
4.31 3.70 267.61 379.87 13.13
4.65 3.85 285.62 389.63 12.97
4.98 4.00 302.62 397.35 12.77
5.31 4.15 321.28 406.59 12.54
5.63 4.30 336.87 411.47 12.55
5.95 4.45 349.89 412.96 12.57
6.27 4.60 364.42 416.08 12.56
6.59 4.75 376.31 416.08 12.62
6.90 4.90 385.50 413.19 12.44
7.24 5.05 387.10 402.60 12.48
7.57 5.20 392.87 396.82 12.41
7.92 5.35 395.75 388.51 12.43
8.27 5.50 400.68 382.62 12.52
8.63 5.65 400.81 372.60 12.40
9.01 5.80 396.65 359.20 12.35
9.40 5.95 391.24 345.35 12.27
MAX: 9.40 5.95 400.81 416.08 13.20
MIN: 0.18 2.20 129.76 290.00 12.27
AVG: 284.84 353.79
Dyno Dan
Run Name: U:\Ford\Mustang\2000 GT\C&L Test\Stock Plenum_002.drf
Run Title: C&L Test
Run Date: 9/6/2003 3:49:58 PM
Stock Plenum_002.drf: 96.43 °F, 27.89 in-Hg, SAE: 1.10
0.16 2.20 N/A N/A 12.88
0.66 2.35 130.32 291.25 12.75
1.10 2.50 141.01 296.25 12.87
1.53 2.65 154.12 305.45 12.98
1.96 2.80 165.27 310.00 13.21
2.37 2.95 179.08 318.82 13.18
2.77 3.10 194.77 329.97 13.05
3.16 3.25 213.29 344.66 13.22
3.52 3.40 233.64 360.90 13.07
3.87 3.55 252.69 373.84 12.88
4.22 3.70 269.15 382.04 12.85
4.55 3.85 288.04 392.94 12.86
4.88 4.00 305.30 400.88 12.64
5.21 4.15 323.70 409.67 12.52
5.52 4.30 338.52 413.47 12.47
5.84 4.45 353.99 417.80 12.49
6.16 4.60 367.01 419.05 12.40
6.47 4.75 378.42 418.42 12.49
6.79 4.90 388.09 415.98 12.39
7.12 5.05 392.93 408.66 12.53
7.45 5.20 396.62 400.59 12.37
7.80 5.35 398.86 391.56 12.46
8.15 5.50 402.10 383.99 12.42
8.51 5.65 402.98 374.61 12.58
8.89 5.80 395.15 357.83 12.25
9.28 5.95 394.20 347.97 N/A
MAX: 9.28 5.95 402.98 419.05 13.22
MIN: 0.16 2.20 130.32 291.25 12.25
AVG: 286.89 356.41
Dyno Dan
Run Name: U:\Ford\Mustang\2000 GT\C&L Test\Stock Plenum_003.drf
Run Title: C&L Test
Run Date: 9/6/2003 3:58:28 PM
Stock Plenum_003.drf: 96.81 °F, 27.88 in-Hg, SAE: 1.10
0.16 2.20 N/A N/A 13.25
0.88 2.35 131.24 293.30 12.97
1.32 2.50 142.31 298.97 13.10
1.75 2.65 154.57 306.35 13.16
2.17 2.80 166.74 312.75 13.09
2.58 2.95 179.97 320.40 13.22
2.99 3.10 194.34 329.26 12.97
3.37 3.25 214.28 346.27 12.74
3.73 3.40 233.89 361.29 12.79
4.09 3.55 252.60 373.70 12.67
4.43 3.70 269.35 382.33 12.70
4.77 3.85 286.88 391.34 12.77
5.10 4.00 304.83 400.26 12.40
5.42 4.15 320.89 406.10 12.27
5.74 4.30 337.29 411.96 12.26
6.06 4.45 351.68 415.06 12.23
6.38 4.60 364.54 416.21 12.14
6.70 4.75 377.81 417.76 12.32
7.02 4.90 385.59 413.30 12.24
7.35 5.05 393.40 409.15 12.26
7.68 5.20 396.54 400.51 12.16
8.02 5.35 399.22 391.92 12.26
8.38 5.50 397.57 379.66 12.01
8.74 5.65 400.42 372.23 12.06
9.12 5.80 395.21 357.88 12.05
9.52 5.95 385.42 340.22 11.88
9.94 6.10 373.08 321.22 N/A
MAX: 9.94 6.10 400.42 417.76 13.25
MIN: 0.16 2.20 131.24 293.30 11.88
AVG: 289.85 354.42
Discussion Starter · #2 ·
Here are the results from the C&L Plenum and BBK TB. I made no other changes and testing was performed in EXACTLY the same manner as before.
Dyno Dan
Run Name: U:\Ford\Mustang\2000 GT\C&L Test\CL Plenum_001.drf
Run Title: C&L Plenum and BBK 75 mm TB
Run Notes: no calibration changes, 14 degrees locked
Run Date: 9/6/2003 5:16:36 PM
CL Plenum_001.drf: 95.90 °F, 27.84 in-Hg, SAE: 1.10
0.14 2.20 N/A N/A 13.17
0.85 2.35 129.87 290.24 13.16
1.29 2.50 141.39 297.04 13.10
1.73 2.65 154.29 305.79 13.29
2.15 2.80 165.74 310.87 13.44
2.57 2.95 179.20 319.04 13.50
2.96 3.10 195.23 330.76 13.39
3.35 3.25 215.46 348.19 13.50
3.71 3.40 235.19 363.31 13.16
4.06 3.55 254.64 376.72 12.96
4.40 3.70 273.26 387.89 13.02
4.73 3.85 291.75 397.99 13.00
5.06 4.00 310.80 408.09 12.75
5.37 4.15 329.10 416.50 12.79
5.68 4.30 345.97 422.58 12.64
5.99 4.45 359.55 424.36 12.54
6.30 4.60 375.20 428.38 12.65
6.61 4.75 385.92 426.72 12.67
6.93 4.90 391.16 419.26 12.67
7.25 5.05 395.55 411.37 12.58
7.58 5.20 399.76 403.77 12.52
7.92 5.35 409.33 401.85 12.46
8.26 5.50 409.11 390.67 12.52
8.62 5.65 409.96 381.09 12.34
8.99 5.80 401.23 363.34 12.34
9.38 5.95 395.27 348.91 12.21
MAX: 9.38 5.95 409.96 428.38 13.50
MIN: 0.14 2.20 129.87 290.24 12.21
AVG: 290.54 360.57
Dyno Dan
Run Name: U:\Ford\Mustang\2000 GT\C&L Test\CL Plenum_002.drf
Run Date: 9/6/2003 5:27:12 PM
CL Plenum_002.drf: 96.23 °F, 27.84 in-Hg, SAE: 1.10
0.22 2.30 N/A N/A 12.92
0.91 2.45 138.27 296.42 12.85
1.34 2.60 150.60 304.20 13.20
1.77 2.75 163.37 312.01 13.21
2.18 2.90 175.75 318.30 13.27
2.58 3.05 190.65 328.29 13.10
2.97 3.20 209.83 344.38 13.25
3.33 3.35 231.13 362.36 13.19
3.68 3.50 251.21 376.96 13.01
4.02 3.65 268.64 386.55 12.91
4.36 3.80 286.76 396.32 12.92
4.68 3.95 306.25 407.21 12.80
5.00 4.10 323.16 413.97 12.64
5.31 4.25 343.64 424.65 12.56
5.61 4.40 356.88 425.99 12.62
5.92 4.55 373.36 430.98 12.62
6.23 4.70 386.03 431.37 12.56
6.54 4.85 394.26 426.95 12.63
6.86 5.00 401.32 421.56 12.59
7.18 5.15 405.80 413.85 12.47
7.51 5.30 408.83 405.13 12.39
7.85 5.45 411.78 396.83 12.47
8.19 5.60 413.81 388.10 12.50
8.56 5.75 405.15 370.06 12.32
8.94 5.90 397.79 354.11 12.29
9.34 6.05 395.84 343.64 12.24
9.75 6.20 390.09 330.45 N/A
MAX: 9.75 6.20 413.81 431.37 13.27
MIN: 0.22 2.30 138.27 296.42 12.24
AVG: 302.97 363.36
Dyno Dan
Run Name: U:\Ford\Mustang\2000 GT\C&L Test\CL Plenum_003.drf
Run Date: 9/6/2003 5:39:52 PM
CL Plenum_003.drf: 96.71 °F, 27.84 in-Hg, SAE: 1.10
0.14 2.20 N/A N/A 12.93
0.67 2.35 131.38 293.61 13.03
1.11 2.50 142.75 299.89 12.96
1.54 2.65 155.95 309.07 13.13
1.95 2.80 168.28 315.65 13.26
2.36 2.95 180.88 322.04 13.33
2.76 3.10 197.45 334.53 13.26
3.13 3.25 218.39 352.91 13.23
3.49 3.40 238.91 369.05 13.16
3.83 3.55 258.62 382.62 12.99
4.17 3.70 275.37 390.88 13.08
4.49 3.85 294.92 402.32 12.89
4.81 4.00 313.88 412.12 12.73
5.13 4.15 333.03 421.47 12.76
5.44 4.30 349.39 426.76 12.67
5.74 4.45 363.54 429.06 12.59
6.05 4.60 378.78 432.46 12.56
6.35 4.75 389.83 431.03 12.62
6.66 4.90 399.38 428.09 12.68
6.98 5.05 405.18 421.40 12.55
7.30 5.20 410.74 414.86 12.56
7.63 5.35 415.24 407.65 12.61
7.97 5.50 416.22 397.47 12.44
8.32 5.65 416.71 387.36 12.61
8.68 5.80 412.45 373.49 12.40
9.07 5.95 403.08 355.82 12.32
9.47 6.10 396.85 341.70 N/A
MAX: 9.47 6.10 416.71 432.46 13.33
MIN: 0.14 2.20 131.38 293.61 12.32
AVG: 298.79 364.94
Dyno Dan
Run Name: U:\Ford\Mustang\2000 GT\C&L Test\CL Plenum_004.drf
Run Date: 9/6/2003 5:58:00 PM
CL Plenum_004.drf: 96.50 °F, 27.82 in-Hg, SAE: 1.10
0.20 2.30 N/A N/A 12.89
0.85 2.45 139.52 299.07 12.87
1.28 2.60 151.99 307.03 13.17
1.70 2.75 165.21 315.52 13.09
2.10 2.90 177.94 322.24 13.37
2.50 3.05 193.49 333.19 13.12
2.88 3.20 213.20 349.91 13.14
3.24 3.35 232.21 364.05 13.05
3.59 3.50 252.89 379.49 12.89
3.93 3.65 270.89 389.79 12.94
4.26 3.80 289.26 399.80 13.06
4.58 3.95 308.74 410.52 12.84
4.89 4.10 327.18 419.12 12.67
5.20 4.25 346.80 428.57 12.55
5.51 4.40 362.02 432.13 12.57
5.81 4.55 376.70 434.83 12.53
6.11 4.70 390.17 436.00 12.75
6.42 4.85 398.71 431.77 12.69
6.73 5.00 405.27 425.71 12.56
7.05 5.15 411.26 419.42 12.57
7.38 5.30 414.00 410.27 12.48
7.71 5.45 417.76 402.59 12.49
8.05 5.60 416.27 390.42 12.39
8.41 5.75 412.77 377.03 12.33
8.79 5.90 403.75 359.43 12.33
9.18 6.05 397.76 345.30 12.16
9.58 6.20 398.50 337.58 N/A
MAX: 9.58 6.20 417.76 436.00 13.37
MIN: 0.20 2.30 139.52 299.07 12.16
AVG: 306.45 367.44
Here is a link to a graph from the runs:
http://www.f150online.com/galleries...69560&anum=2142
Here is a link to graph that compares the best baseline vs. the best C&L / BBK 75mm TB run:
http://www.f150online.com/galleries...69561&anum=2142
What is interesting and I can't explain is how the C&L Plenum and BBK 75mm TB continued to make better power each successive run. The power did stabilize (I did back up runs), but I've never seen this before, and god knows I've done thousands of tests.
Here is a link to a run after a LONG cool down, I would say that an hour had past. I warmed up the car to the same temp as the test runs (176 degrees ECT) and then dropped the hammer! I was floored, the little 2v is making some steam, and this is the 91 octane pump gas tune.
http://www.f150online.com/galleries...69567&anum=2142
As soon as time permits, I'll fill 'er full of 100 octane and lock the timing at 19 degrees........but according to my datalogs, the little Focus ("Chicane") pump is about done. It's time for a 2003 Cobra tank / dual pump set up, but I'll ditch the stock 03 pumps in favor of a pair of the Focus ("Chicane") pumps.
