I'm planning on doing a solid swap into my 04 Cobra and was wondering if there's any issue between diffs and c clip or non c clip axles. I'm pretty much set on the idea of using an 02 gt rear, with 31 spline c clip axles, and a Detroit tru-trac differential, any problems with that? I'm just curious how you can get to the c clips with those aftermarket diffs, seems like you wouldn't have access to remove or install the clips?? Please tell me I'm wrong and that I can use any axle with any diff. as long as the splines are the same!
