1 - 16 of 16 Posts
I've heard that some cars are having problems with the factory cats. I've only had my car for a few days now and it only has 500 or so miles on it, but whenever I run it kinda hard then stop, I smell something sorta like burnt plastic. I opened the hood tonight, and I can't smell it.
It definately is coming from the exhuast. There could possibly be something on the exhaust somewhere that is getting hot and burning, but after talking to Rick @ Amazon, he thinks it may be the cats.
Anyone else having this problem?
I'd give it some time, the car is too new to tell. It could be some coating burning off, or even the catalytic material "breaking in". I wouldn't worry about it now.
After you run your car hard stop and take a look at the cats if they are glowing red then you have a problem. If not they are probably just burning in.
Eric,, You will smell that Cobra for more then 1000 miles.
I remember reading all the guys complaining about the same thing.
I thought my cats were bad also because they were discolored..That is normal.. Glowing Red is not normal..
just look under the car when it's hot..
Eric,
Don't worry about it. My car more smells than I knew existed. Like Jimmy said, after about 1000 miles most of it will go away. I have about 6500 on the car now, and at least I still have a faint new car smell inside. All of the other smells are gone.
Mine reaked for a 1000 miles or so....all is well at 7500. Give it some time to break in....
Eric, could you have had the same bad luck I did? On the way home from the dealer I had a plastic bag blow in front of me on the freeway. Naturally it stuck to the pipes just in front of the cats. Even though I yanked it right off it still stank for another couple of weeks.
The clogged cat problem is only when the car is very new. The problem was the cats were loading up with fuel in the begining from being started and shut off without coming to operating temp. The big injectors would load the cats with fuel and then eventually melt down when new. This was only a problem the 1st 4 months or so that Cobras were produced. I havent seen a Cobra at our dealer with bad cats in prolly 7 months.
I am just over 3k on mine and I can smell them more now than ever. Of course I was easy until 2.5k.....then started doing the back roads heating things up. Like everyone is saying...no worry unless they are glowing. You will probably replace them in your first mod anyway!
So basically what I'm hearing is, if you want to avoid the smell, replace the cats within the first couple hundred miles???
Has anyone NOT HAD this smell problem?
Really though.... Has there been anyone who does not/has not had the smell problem with their Cobra??
Just want to know if anyone has avoided it...
My car never made any weird smells.
An 03' w/ clogged cats will hesitate terribly at high RPM and not want to go over 5500rpm.. that's what mine did when it had the clogged cats. Jerry
1 - 16 of 16 Posts
