i was reading this on another forum. since everyone is talking about the kenne bell for the 03 cobra, has anyone put a vortech or a novi in the 03 cobra engine? i mean would they produce the same or even more hp than the kb? and since they build boost at higher rpms right, can they compete with the turbo 03 cobras?
Davidmax put an ATI supercharger on his 03, but he also went with a 5.2-5.4L aluminum block, custom heads and cams. . .ect. So he got more hp than someone would get if they just swapped the blower and did some bolt ons.
Personally, I don't think its worth it. If you are going to go through the extra trouble off taking off the eaton and replacing it with another intake manifold and then running a different power adder, it would only be worth it if you went with a turbo.
A vortech may make some more hp up top, but we would loose alot of low end power. Its just not worth it to swap from one supercharger to another (on a street car). If your going to get rid of the eaton, keep it simple and get something that will fit in its place (KB).
It's hard to beat theKB recipe for 600rwhp...Cheaper,No plumbing nightmares and they drive like stock cars...
