It really isnt that bad. You have to brace the engine up, and drop the K. It can be done in 2-3 hours from start to finish. To brace up the engine, if you have an engine hoist...thats the easy ways=. My way, is to use a 2x4 and cut it to fit exactly between the fenders (the lip where the hood sits in, and where the fender bolts are). I actually use 4 2x4's for safety. 2 screwed together and one at the front of the engine and one at the rear. Then use a set of straps or chains, hook it to the engine. I drew a picture to show how I did mine and it has worked flawlessly. I did go to lowes/home depot and bought some long bolts that fit the intake manifold bolt holes and put some large washers on them.
