1 - 13 of 13 Posts
...and i need project funds
***no paypal! money order/cashier's check acceptable. cash loved***
would prefer local meeting on most of it, definitely on the large stuff(seats/wheels/rear)
i am in College Station TX and my parts are here or in Waller TX. can arrange meeting/dealing.
SCT PRP software, Raptor data logger, and chip burner, all new - 500
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0526.jpg
On3 4v 2nd gen(forward-facing headers) hotside. all new, never ran.
Hellion coldside w/ Godspeed intercooler. also all new, never ran.
1900, no turbo included. otherwise complete.
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0411.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0410.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0409.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0408.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0407.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0406.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0413.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0414.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0415.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0416.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0528.jpg
80mm BILLET WHEEL Comp Turbo. .96 A/R turbine standard journal bearing, water cooled. cost 2200 new. also new, never mounted. this was spec'd to spool by ~3500 on a stock '03 Cobra.
Turbochargers Comp Turbo - CT43-8079 Standard
1700 for turbo.
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0433.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0434.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0435.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0436.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0437.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0438.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0439.jpg
3400 for whole turbo setup.
debating changing my setup. if this kit sells i will, if not i'll go thru with my current plan.
drivetrain:
built 99-04 8.8 SRA
Auburn pro series 31-spline diff
Superior axles
Motive 4:10 gears
T/A girdle
1,000 obo. or trade for stock rear + 6-700ish(negotiable). PENDING trade
sn95-length Moser axles, 31 spline, 94-98 - 180
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0519.jpg
nitrous parts:
4v/lightning nitrous plate, for dry or wet nozzle. - 40
NOS old style remote bottle opener - 60
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0334.jpg
bottle brackets 20/set for steel, 40 for stainless, have one of each.
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0335.jpg
DynoTune 2 stage window switch - 120
MSD window switch - 80
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0336.jpg
fuel:
Glenn's performance 600hp kit for 99-04 w/ sumped tank. brand new, not even mocked up. missing one fitting and short -10 line(maybe 50 to replace) - 800
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0531.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0530.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0499.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMG958183.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0440.jpg
80# FRPP/Cobra Jet injectors, near new - 300
VMP HPX MAF w/ 100mm inlet tube and plug and play harness, no air filter, stock maf(good to 600ish) - 220
VMP Tuning - Buy Ford SCT & GM Custom Handheld Flash Tuners Performance Economy Towing: VMP 100MM MAF Conversion Kit for 03-04 Cobra
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0462.jpg
Holley blue pump, regulator, and lines - 200
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0341.jpg
intake:
JLT CAI black tube/couplers only - 100
JLT RAI, white, beat up - 60
professional products 2v tb and plenum - 120
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0516.jpg
96-04 coolant reservoir, needs polishing, but no damage - 80
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0500.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0501.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0502.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0503.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0504.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0505.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0506.jpg
ported NPI heads.
complete fresh from machine shop, fresh valve job and pressure check.
ready to bolt on, complete with COMP springs and stock cams.
300 obo.
http://i1222.photobucket.com/albums/dd491/dinolord05/10.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/11.jpg
suspension/brakes:
QA1 k-member for 96-04, brand new - 200
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0379.jpg
PA racing fox-length a-arms, used, but good shape - 150
D&D coilover kit, near new - 100
Eibach front drag springs - 60
'03 Mach 1 front brakes, complete pull-off(spindles, hubs, calipers(painted blue), rotors, etc) - 400
QA1 single adjustable struts, 5 passes, 99-04 - 220
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0518.jpg
QA1 single adjustable shocks, never run - 200
comp engineering 90/10 struts and 3-way adjustable shocks, fox-length - 200
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0412.jpg
UPR pro series upper and lower arms, 79-98 - 160
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0517.jpg
energy suspension 96-04 4.6 motor mounts(new) and 99-04 trans mount(lightly used) - 140
exhaust:
BBK catted H-pipe for long tubes, 96-04 - 120
stock 05-09 mid pipe - 60
MAC tips and attaching pipes - 80
magnaflow catback for IRS, has some scratches/scrapes, but in good functional shape, will clean up from what you can see on the car - 280
bassani cat-back for 98-04 solid axle, great shape - 400, trade for (uncut) stock + 300 - PENDING
05-09 Flowmaster axleback - 120
wheels/tires/etc:
mach wheels:
pair of 17x10.5 deep dish w/ near-bald 315 sumitomos - 400 - PENDING
pair of stock wheels near-new(20 miles) 275-40 nitto 555R drag radials - 350
can add a pair of stockers w/ like 245-40's to either for 200 more. - PENDING
all wheels are in good, used shape. no rash, but some chips/light clear peeling.
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0481.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0482.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0483.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0484.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0485.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0452.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0453.jpg
Diamond racing wheels w/ 28-10.0-15 Hoosier slicks
will clear Cobra brakes AND IRS!
wheels have paint chipping, not bad. tires have 5 passes on them, tons of life left.
250 obo
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0313.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0314.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0315.jpg
Bogart front skinnies w/ front runner tires
wheels are near perfect, couple light scratches. tires have a little life left in them for track use
clear cobra brakes!
250 obo
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0310.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0311.jpg
26-10-15 ET Drags, near new, but one has sidewall cuts - 50 - PENDING
335-30-18 Michelin Pilot Sports, used, but good. oooold, but very lil weathering - 50 each
http://images1.snapfish.com/232323232fp:;2>nu=3396>872>964>WSNRCG=3448525;53335nu0mrj
335-35-17 Hoosier drag radials, 20 miles, basically new -
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0205.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0206.jpg
pair of 18x10 saleens, will need paint. - 100
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0207.jpg
265-35-18 BFG KDWs, like new, 260 miles - 260
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0268.jpg
interior
misc 99-04 dark charcoal interior pieces from '99 GT, '01 Bullitt, and '03 Mach. airbags, carpet, plastics, consoles, etc- ask
exterior:
OEM '95 Cobra R. brand new, never mounted or painted, perfect - 350
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0494.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0490.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0491.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0492.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0493.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0495.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0496.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0497.jpg
'03/'04 Cobra rear bumper. was damaged, now 90% repaired, needs final finishing, sanding, and then paint. brackets still perfect. no lenses - 150
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0512.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0513.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0514.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0515.jpg
Mach 1 scoop, upper and lower pieces - 150
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0488.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0487.jpg
sn95 smooth trunk lid, needs paint - 50
'99 black trunk lid w/ shaved holes. not done perfect, but a good 5-footer. has hole drilled for battery kill switch- 40
99-04 taillights, pair - 40
black 01-04 GT/mach side scoops. scratches, should paint. couple messed up tabs, but very usable. - 60
electronics:
have a few misc 99-04 computers and harnesses laying around - ask
4v coil packs - 50/set
03/04 cobra parts:
stock 03-04 fuel rails(have 2 sets) - 40 each
intake tube - 30
EGR sensors w/ bracket - 40
lower alternator bracket - 30
http://images1.snapfish.com/232323232fp::2>nu=3396>872>964>WSNRCG=34427767:7335nu0mrj
Discussion Starter · #2 ·
**UPDATE**
built 4.6 4v engine(about 20k miles)
Built by HPP racing, made 368hp/350tq on motor through stock intake
Cobra iron block
Cobra crank
Manley H-Beam Rods
J&E pistons (very close to stock mach compression - 10.5:1)
lightly worked heads
Crower Stage 2 cams
Comp valve springs
complete valve cover to oil pan
3500 OBO
PMP 3650
aluminum flywheel
Spec 3 clutch
Pro 5.0 shifter
all with about 10k miles, works perfect, shifts AWESOME!
1800 complete, 1500 for trans alone. OBO.
1599 for turbo.
drivetrain:
built 99-04 8.8 SRA
Superior axles
Motive 4:10 gears
T/A girdle
sn95-length Moser axles, 31 spline, 94-98, 3" studs installed - 180
nitrous parts:
MSD digital window switch - 120
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0540.jpg
MSD tach adapter - 80
Zex wet kit for Mustang, missing feed line - 250
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0539.jpg
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0541.jpg
fuel:
intake:
http://i1222.photobucket.com/albums/dd491/dinolord05/IMAG0525.jpg
ported NPI heads.
300 obo.
suspension/brakes:
UPR pro series adjustable uppers and lowers for 79-98, lightly used - 150
exhaust:
BBK catted H-pipe for long tubes, 96-04 - 120 - pending
magnaflow catback for IRS, has some scratches/scrapes, but in good functional shape, will clean up from what you can see on the car - 280 - pending
wheels/tires/etc:
250 obo
335-35-17 Hoosier drag radials, 20 miles, basically new - 350
265-35-18 BFG KDWs, like new, 260 miles - 250
interior
exterior:
electronics:
03/04 cobra parts:
intake tube - 30
i am in College Station TX part time for school and my parts are in Waller TX. can arrange meeting/dealing.
SCT Raptor datalogger - 150
SCT Xcal 2's, have 3 w/ unused status - 150 each
Cobra iron block
Cobra crank
Manley H-Beam Rods
Crower Stage 2 cams
Comp valve springs
3500 OBO
PMP 3650
aluminum flywheel
Spec 3 clutch
Pro 5.0 shifter
1800 complete, 1500 for trans alone. OBO. - PENDING
1599 for turbo.
drivetrain:
built 99-04 8.8 SRA
Superior axles
Motive 4:10 gears
T/A girdle
nitrous parts:
fuel:
Glenn's performance 600hp kit for 99-04 w/ sumped tank. brand new, not even mocked up. missing one fitting and short -10 line(maybe 50 to replace) - 750
Holley blue pump, regulator, and lines - 150
intake:
ported mach intake, not cut open, just port matched on lower and upper smoothed - 400 or stocker + 250
ported NPI heads.
300 obo.
suspension/brakes:
comp engineering 90/10 struts and 3-way adjustable shocks, fox-length - 150
QA1 single adjustable front struts, handful of passes - 200
QA1 single adjustable rear shocks, bolted in, never run - 180
energy suspension poly motor(new) and trans mounts(like new) for 4.6 - 150
exhaust:
wheels/tires/etc:
250 obo
interior
exterior:
electronics:
03/04 cobra parts:
intake tube - 30
Discussion Starter · #11 · (Edited)
newest:
would prefer local meeting on most of it, definitely on the large stuff(motors/wheels/rears, etc)
2 in aftermarket status(locked) - 100 each
AEM wideband 30-4100, brand new in box - 150
Innovate wideband MTX-L wideband, brand new - 150
Fluidyne radiator for '96 Mustang GT/cobra, great shape - 150
stock Mach motor, runs great, intake to oil pan - 2000
Cobra iron block
Cobra crank
Manley H-Beam Rods
Crower Stage 2 cams
Comp valve springs
3000
PMP 3650
aluminum flywheel
Spec 3 clutch
Pro 5.0 shifter
'97 Cobra T-45, unknown miles, but shifts and drives great - 400
1500.
drivetrain:
built 99-04 8.8 SRA
Superior axles
Motive 4:10 gears
trick flow girdle
cobra brake brackets
built 94-98 8.8 SRA
FMS/Cobra 31-spline diff
Moser axles
FRPP 3:73 gears
T/A girdle
GT brake brackets
welded tubes
700 obo. or trade for stock rear + 3-400
nitrous parts:
fuel:
Glenn's performance 600hp kit for 99-04 w/ sumped tank. brand new, not even mocked up. missing one fitting and short -10 line(maybe 50 to replace) - 650
intake:
ported NPI heads.
250 obo.
suspension/brakes:
comp engineering 3-way adjustable shocks, fox-length - 50
QA1 single adjustable front struts, handful of passes - 180
QA1 single adjustable rear shocks, bolted in, never run - 160
exhaust:
MAC tips and attaching pipes, from 99-04 SRA catback - 80
magnaflow tailpipes/tips for IRS, good, used shape - 120
wheels/tires/etc:
stock Bullitts, pre-05. 3 are silver, 1 anthracite. light rash, good shape. - 250 obo, 550 obo w/ near-new 245/45 Kumhos.
250 obo
335-30-18 Michelin Pilot Sports, used, but good. oooold, but very lil weathering - 30 each
interior
exterior:
Mach 1 scoop, upper and lower pieces - 100
electronics:
03/04 cobra parts:
intake tube - 30
Discussion Starter · #12 ·
updated:
Fluidyne radiator for '96 Mustang GT/cobra, great shape - 150 or 200 with fan
http://i1222.photobucket.com/albums/...5/IMAG0695.jpg
http://i1222.photobucket.com/albums/...5/IMAG0694.jpg
Cobra iron block
Cobra crank
Manley H-Beam Rods
Crower Stage 2 cams
Comp valve springs
3000
PMP 3650
aluminum flywheel
Spec 3 clutch
Pro 5.0 shifter
1500.
http://i1222.photobucket.com/albums/...5/IMAG0433.jpg
http://i1222.photobucket.com/albums/...5/IMAG0434.jpg
http://i1222.photobucket.com/albums/...5/IMAG0435.jpg
http://i1222.photobucket.com/albums/...5/IMAG0436.jpg
http://i1222.photobucket.com/albums/...5/IMAG0437.jpg
http://i1222.photobucket.com/albums/...5/IMAG0438.jpg
http://i1222.photobucket.com/albums/...5/IMAG0439.jpg
drivetrain:
built 99-04 8.8 SRA
Superior axles
Motive 4:10 gears
trick flow girdle
trade for stock/geared rear + 6-700ish(negotiable)
built 94-98 8.8 SRA
Moser axles
FRPP 3:73 gears
T/A girdle
GT brake brackets
welded tubes
nitrous parts:
http://i1222.photobucket.com/albums/...5/IMAG0334.jpg
http://i1222.photobucket.com/albums/...5/IMAG0335.jpg
http://i1222.photobucket.com/albums/...5/IMAG0336.jpg
http://i1222.photobucket.com/albums/...5/IMAG0540.jpg
http://i1222.photobucket.com/albums/...5/IMAG0539.jpg
http://i1222.photobucket.com/albums/...5/IMAG0541.jpg
fuel:
http://i1222.photobucket.com/albums/...5/IMAG0531.jpg
http://i1222.photobucket.com/albums/...5/IMAG0530.jpg
http://i1222.photobucket.com/albums/...5/IMAG0499.jpg
http://i1222.photobucket.com/albums/.../IMG958183.jpg
http://i1222.photobucket.com/albums/...5/IMAG0440.jpg
http://i1222.photobucket.com/albums/...5/IMAG0341.jpg
stock 99-04 2v and 4v fuel rails - 40 each
intake:
http://i1222.photobucket.com/albums/...5/IMAG0525.jpg
ported NPI heads.
250 obo.
http://i1222.photobucket.com/albums/...olord05/10.jpg
http://i1222.photobucket.com/albums/...olord05/11.jpg
Lightning crank - came from a JLP shortblock with less than 5k miles, been sitting, a lil clean up and it's ready to go - 150
http://i1222.photobucket.com/albums/...5/IMAG0692.jpg
http://i1222.photobucket.com/albums/...5/IMAG0693.jpg
suspension/brakes:
http://i1222.photobucket.com/albums/...5/IMAG0412.jpg
exhaust:
wheels/tires/etc:
250 obo
http://i1222.photobucket.com/albums/...5/IMAG0313.jpg
http://i1222.photobucket.com/albums/...5/IMAG0314.jpg
http://i1222.photobucket.com/albums/...5/IMAG0315.jpg
http://images1.snapfish.com/23232323...%3B53335nu0mrj
http://i1222.photobucket.com/albums/...5/IMAG0205.jpg
http://i1222.photobucket.com/albums/...5/IMAG0206.jpg
interior
exterior:
http://i1222.photobucket.com/albums/...5/IMAG0494.jpg
http://i1222.photobucket.com/albums/...5/IMAG0490.jpg
http://i1222.photobucket.com/albums/...5/IMAG0491.jpg
http://i1222.photobucket.com/albums/...5/IMAG0492.jpg
http://i1222.photobucket.com/albums/...5/IMAG0493.jpg
http://i1222.photobucket.com/albums/...5/IMAG0495.jpg
http://i1222.photobucket.com/albums/...5/IMAG0496.jpg
http://i1222.photobucket.com/albums/...5/IMAG0497.jpg
http://i1222.photobucket.com/albums/...5/IMAG0488.jpg
http://i1222.photobucket.com/albums/...5/IMAG0487.jpg
96 convertible frame, pump, and hoses. worked good. top itself is trash - 200
http://i1222.photobucket.com/albums/...5/IMAG0690.jpg
electronics:
03/04 cobra parts:
intake tube - 30
http://images1.snapfish.com/23232323...7%3A7335nu0mrj
Discussion Starter · #13 ·
Cobra iron block
Cobra crank
Manley H-Beam Rods
Crower Stage 2 cams
Comp valve springs
3000
PMP 3650
aluminum flywheel
Spec 3 clutch
Pro 5.0 shifter
1500.
drivetrain:
built 99-04 8.8 SRA
Superior axles
Motive 4:10 gears
trick flow girdle
built 94-98 8.8 SRA
Moser axles
FRPP 3:73 gears
T/A girdle
GT brake brackets
welded tubes
nitrous parts:
fuel:
intake:
ported NPI heads.
250 obo.
suspension/brakes:
exhaust:
wheels/tires/etc:
250 obo
interior
exterior:
electronics:
03/04 cobra parts:
intake tube - 30
1 - 13 of 13 Posts
