[HR][/HR] I just installed a used built T45 in my 03. I was given a used ProMotion clutch/PP (believe the pressure plate is ACT, not sure on the disc). I installed a new FRPP steel flywheel, new pilot and throwout bearing from Ford. Car shifts fine, but i did have 5th gear pop out once while driving. I was hunting an oil leak the other day, so under the car while running, i slid back near the trans to inspect it while running since i noticed the fork was vibrating. I pushed the fork towards the back of the car and the vibration stopped since the TOB was barely to not touching the PP fingers now. Not sure if this is normal? Been awhile since i dealt with a manual trans. I put a carbarator spring on the fork to pull it away off the PP and the fork now doesnt vibrate.
