1 - 5 of 5 Posts
i have tried moving the coil pack, putting in a different plug, and now im stuck.
i don't understand what else the problem could be.
i checked all the things i could from the ford cd but nothing stood out.
i can't trace the wire all the way from the cop to the pcm as its wrapped with tape and goes all over the place.
any help on this?
Did you figure this out yet??I have access to all the needed wiring diagrams so you can check your wire for continuity at the e.c.m.Let me know if i can help.
Mike
i figured it out and it turned out to be rather expensive. I had a bent pin on the computer.
a new computer later, car runs like a champ.
now for some valvesprings.
Hey mike. Mike here. Im having he same problem as this guy along with a p0358 code also. Could you please send me a wi re diagram for this car. 1997 lincoln mark viii base model. I would really appreciate it
1 - 5 of 5 Posts
