I will be rebuilding my 4.6 to either a big bore 5.0 or just leaving as 4.6
1. What compression ratio do you guys recommend for 15psi of turbo boost? I suspect it will be full boost by 3500rpms and this will be on pump gas
2. There seem to be different type of resleeving materials when going to the big bore 5.0 DOHC, is there any material I should stay away from or look for?
Call Scott at SHM.He had a special lowcomp set made for my motor.Not sure all the specifics,but he knows his $hit!
Tell'mm Super Kaz referd you for special Deal!
Kaz.....................:D
I agree, Scott at SHM is very helpful and knowledgeable.
