1 - 5 of 5 Posts
i p ulled my dohc 4.6 out of a 95 continental. are they the same motor as the mark viiis?
and if i run a 98 cobra ecu would i have to run a 98 cobra wiring harness? would it be easier to run the 98 cobra wiring or 03-04 cobra wiring?
Block is different, and won't work.
You can use everything but the block, since Contis are FWD and the rear of the block is set up for a transaxle. As far as your wiring question, it's hard to answer without knowing what your plans are for your build.
im not going to do the eaton swap. but i am going to convert over to the c-heads instead of b heads and i want to turbo charge the motor with a 6-speed behind it. i got a ecu as a freebie & i got dont want to spend the money to buy a new one for a 03-04 cobra.
a legend in my own mind
b heads are better for turbos.
1 - 5 of 5 Posts
