use stainless steel staples
Be prepared for a big job. If you are good at upholstery, this will help a lot. If you are a "right" brain engineer type, consider enlisting the help of someone with a "left" brain. This is not an exact science but more like an art form (that is the reason I personally would never attempt).
Make sure to use stainless steel staples. If not, they will rust and you will be re-doing it.
If you are replacing the top (and changing color), you will need a new rear wind screen (window glass) as well.
On other posts, I have read recommendations to clean and paint the convertible top hoop molding. It is much easier to do off of the car.
