If you maintain the OEM heater feed plumbing on the back of the passenger head that feeds into the water pump cavity from between the two cylinder banks, you might be OK, but I would not bet a set of heads on it, especially expensive, modified heads. When the passenger side head has no way to return coolant to the radiator, it will overheat. Normally it is the driver-side head that experiences this problem because of the lack of a coolant path out the back of the head like the passenger-side head. I would highly recommend the use of the coolant return ports on the front of each head.
When the heads overheat, the first sign of trouble is frequently the OEM exhaust seats loosening up and falling out. You are having aftermarket seats installed so this type of failure would be less likely but not inconceivable. For the cost and effort involved, I would use both return ports on the front of the heads.
