Hey guys when i was installing my headers, and motormounts, the engine rocked back and smacked the firewall, and apparently puctured the hose that goes from the head to the heater core.
Can you remove this line easily by taking the intake off, or can you remove the wiring harness
Anyone that has done this please explain to me, i would really like to know!
Thanks
I changed mine without pulling the intake. I didn't disconnect the main wiring harness either. I believe I just pulled a few vaccum lines. It's been awhile. I just reached down there with a shorty screw driver and loosened the hose clamp and pulled the hose off.
You must have had someone add a screwing hose clamp, the ford factory uses those bitch metal clamps, you have to use pliers, and i cant get enough room
too bad it isnt a screw one, it would be easy! ;)
