What's everyone using to pressure test their cooling systems? I might be borrowing one this weekend, but I think I might just buy one so I have it incase I have this problem again.
Been chasing a leak for like a month that only happens after car sits overnight and cools off. The coolant that's leaking is getting into my spark plug holes and causing the COP's to misfire. I have to blow them out with compressed air everytime I drive the car after letting it sit overnight. Looks like it's leaking around t-stat housing, but I replaced thermostat and o-ring and it's still leaking. Intake was replaced by ford about a year ago cause the plastic one cracked so I have the updated one with metal crossover.
I know that you need a special adapter to pressure test these cars cause of the plastic overflow bottle.
Let me know what you guys are using!! Thanks.
buddy of mine is having the same issue and its boggling my mind we also replaced everything including the radiator grrrrrrrrrr
als i ti only leaks under load, never sitting
i fixed all my leaks. Both my upper and lower hoses AND the thermostat housing were all leaking. Me thinks someone must've messed with my car when I walked away with the hood open lol. Weird that they all started leaking at same time. I ended up borrowing a snap on pressure tester from my friend that had the right adapter for our coolant overflow tanks.
Makes it way easier to find the leak with a pressure tester, def worth buying one
