Borrowed some technology from the GM guys and put together a crankcase evacuation system. The vacuum pump is an electric air injection pump used on many late 90s GM cars, it's plumbed into the cam cover, and on to a catch can. Had an adapter welded to the driver's side cam cover nipple so an oil separator/breather could be screwed on, plumbed a pcv valve on the other cam cover nipple and on to the catch can. Racetronix makes a plug and play fused/relayed wiring harness, it also includes an adjustable Hobbs switch to turn on the electric pump at 3-7 lbs. of boost. Reducing crankcase pressure produces 20-30 hp on GM engines, hopefully it will do as well on my built 4.6. I'll be installing the wiring harness tomorrow and will get the car dynoed later this week. I'll keep you posted.
