Ed,
I plan on purchasing a custom set of your designed Gibetec mod motor pistons . I have a question if you don't mind please sir.
From reading the thread you created a few years back it looks like the Gibtec's were designed with a center pin vs offset . I was wondering if you could elaborate on the advantages and dis-advantages if any on both styles please. My application is turbo
street/strip .
Second question kind of off topic would be on main bearings will the king MB5281SI matched with MB5219SI for the fully flanged thrust bearing setup work on the Teksid block ? The thread I read over was on a 05+ nemark style block .I assume all aluminum blocks use the same main bearings but that is just a assumption. This is my first 4.6L 4v rebuild so I have been reading alot of threads here on MFF and taking notes. Lots of good info for sure !
Thanks! Mike
street/strip .
Thanks! Mike
