1 - 11 of 11 Posts
I know most of you guys aready have made up your mind on air intake but on the chance someone is interested, I thought I would post this.
Both dyno runs were the second run that day on the dyno. They were done 1 week apart and weather/temp was similar. The peak HP was close (5HP) but the HP gain until 5000 RPM looks to be about 15HP-20HP greater. The torque number is what I was most surprised by. 50 higher TQ. The denscharger actually made more power with a richer A/F after 4700 RPM.
I am not promoting one product over the other because I am happy with both. Rather, I am sharing my experiences so others can have more information for their decisions.
These are the parts I purchased.
System #9: Part# CF03CFL
03 Cobra Meterforward system
Includes Densecharger System with new CNC'd MAF Flanges,
Carbon Fiber trimmed pipe and cover plate, and Black/Chrome decals
K&N # 3480 6" Conical Air Filter
& I am not sure about which run the C&L is but here is a picture
Your numbers are very impressive. Autologic seems to be doing well on these cars!
The runs were started at different revs. The red was almost past peak torque when the pull was started.
True, but at the same RPM there is still a huge diference. I might be wrong but my understanding is that: regardless of when the run is started, the dyno should return the same numbers for that RPM (meaning 2 pulls done on the same day with no changes could start at different RPM's and the numbers should be the same at the same RPM). I have several dynos which would indicate that to be true, But, like I said, I am no expert.
I am real happy with the autologic after having a lot of problems with my Diablo (probably all tuner but I still wouldn't go back)
Eric Brooks said:
Which run is the C&L, and which is the DC?
Sorry I was in hurry to leave the office last night when I rean your post and didn't answer it right.
Run 19=C&L Run 24=Densecharger
Daryl; Was the car tuned before or after the C&L was installed?? We have found the C&L worth as much as 31 hp over the stock meter, filter combo on an unchipped car, but on a chipped car it made almost nothing, unless retuned as it leans the mixture out at least one full point. Joe
Discussion Starter · #11 ·
I installed the C&L and Diablo chip at the same time. Gave up on the Diablo chip and went with autologic. Installed the densecharger after I had the autologic for a while. I have heard several local tuners say the same thing about tuned results.
1 - 11 of 11 Posts
