Over the Memorial day weekend I swapped a 97 DOHC into my 94 GT. The physical swap was easy. Installed a Griggs k-member, dropped in the engine and tranny, installed the cobra pcm and wiring harness and I thought everything would be ok.
Well I couln't get it to start. I tried for two weeks and narrowed it down to the pcm not powering up. I hard wired the pcm and the fuel pump comes on, the PATS authenticates, it turns over but doesn't start.
It seems that there is no spark. Since I hardwired the power to the pcm i think whatever is causing the pcm to not get any power is preventing the car from starting.
I check to see if the coil packs are getting 12v and they are.
I have tried two dealerships in my area, both svt and non and they can't figure it out.
HELP!
hard to diagnose from here......
There could be literally dozens of things wrong, the best thing to do is to find a competant local mechanic to go over the wiring and find the culprit
