1 - 6 of 6 Posts
i was wondering how much of a differance dr's make..1/4 mile wise in my situation.
Put in a set of 4.30 or 4.56 with a pair of 275-60-15 drag radials and you could drop your 60' down to 1.6 easily. that would put you in to the 11's. But thats just my opinion, anything smaller or shorter than the 275-60 is a waste of a drag radial on a power adder car.
kozumasbullitt said:
With practice you should be able to cut high 1.7 to low 1.8 60's on DR's Which can drop your Et close to 4/10's. On the bottle I was cutting low 1.7 60's
it depends on how much your spinning with each gear shift as well, cause if your spinning the tires on every shift I would say .5-.7 drop in time
1 - 6 of 6 Posts
