1 - 8 of 8 Posts
This is the dynograph from my last visit at the dyno. Im pretty impressed. These are STD #'s on the chart below, not SAE. SAE is 473/495
MAX 494whp 518TQ STD
All 3 of these runs were done in a 5 minutes period, notice the dropoff in #'s
Discussion Starter · #2 ·
air fuel for the 2nd pull
Its whack and a tad lean, it hasnt detonated yet or pinged. I dont like it though, although IF I can get the 12.6 accross the range, I know these cars run lean in the midrange, but oh well.
Impressive numbers....except for the A/F. I wonder what is keeping it so "whacked"? I guess I would be concerned too. I was trying to remember what changes you were going to check out on the dyno. The "X" pipe? Anyway, good to see that you are still working at it. :D
Broke7,
Those are some very impressive numbers but you have a very serious air-fuel situation with the boost you are making.Either your chip is not making good contact with your computer or your dyno air-fuel filter needs changed for more accurate results.Most chips from any tuner will start adding alot of fuel around 3000rpms to a safe area than leveling off with a pullied car and yours does not come into until after 5000rpms which that type of air-fuel graph you have it looks like with a non-chipped pullied car.Your air-fuel should be at least in the 12's between 3000-4000rpms and leveling from there.
Yeah Allan I would say its gotta be something in the A/F equipment, dont think the car would have been together this long with that A/F the way you beat on it!
Snake Charmer
Im surprised your seeing as much low end torque as you are with the A/F being so lean at low RPM.
Holy Torque Batman!!!
Those are really good numbers for a car with as little mods as yours. I dont know how you can drive her around with an A/F like that, I'd be scared to death.
Here is something very interesting. This is my dynograph for the same tune with Stock Hpipe and Stock Catback piping, in STD Rating as well. Its rich as hell in this tune
Makes no since
1 - 8 of 8 Posts
