Wings65288 said:
nice signature you lucky bastard, i tell my friends about you how you have a '03 cobra and it's trailered by a '03 lightning! =) .
It definetly doesn't suck :beerchug:
anyways, i'm not sure why you reversed it and it sounds like you may have your 12v red power wire in the wrong spot, i don't really understand. also, you definently want the bung pre-cat and on the driver side because something is definently not right if your reading 13-14 at WOT... it should be 11.5-12 i believe, mines at 11.5. please let me know why you put the red power wire to pin 91, i think thats not right but i'm not sure
Maybe I was confusing. I did mine like this.
Red Power wire to the Defroster Switched Power
Black Ground to the PCM Ground
Black/White Ground to PIN 91 TPS Ground
Those wires are on the same connector that plugs into the wideband.
Grey wire thats on all those other mess of wires that you don't use unless you hook up a switch or trigger a relay goes to TPS Voltage or whatever its called on Pin 88 or 89 I forget now.
Orange wire goes to Pin 26 for RPM.
Yellow Wire that was in the box not connected to anything plugs into the connector that the orange wire is on and then goes to the MAF Voltage which is 88 or 89.
I think the ground I used at the PCM isn't good enough or I have the "smoothing" all the way on which is why it reacts slow. I have to check later tonight and I'm going to move the ground to a better location.
Tried to get the bung welded in pre-cat today but the exhaust shop wasted my time.
Hope that clarifies!
I don't know why everyone is wiring into the fuse block way back on the other side, just tap into the defroster power wire and call it a day.
