I was wondering how to put the factory fan on a toggle switch? i hear that all you have to do is find the right wire on the harness and ground it and the fan will work. Is this correct? Also, does anyone know which wire it is?
Any advice is appreciated.
Thanks in advance,
Steve
I guess if you wanted to, you could hook in a temp sensor with an adjustable knob so you could just set the "fan on" temp lower than factory. This way you would not have to remember to turn it off when it hit the temp you wanted.
