I did a search but couldn't find anything definitive.
I just did an engine swap in my 2002 GT from my old 4.6 2v (romeo) to a low mileage 4.6 2v (romeo) out of an 01. For some reason, the pump isn't sending fuel to the fuel rails. I unbolted the fuel rail and no fuel came out at all. I checked the red reset button in the trunk (just in case) and that was still pushed in. All connections are in place and all the injectors are plugged in. Would this be a PATS issue? It blinks once ever second or so when the car is off (I can't remember if that was normal or not). It doesn't blink when I have the key turned to the on position. There is only wire I think could be a concern. When I pulled the engine a wire on the drivers side got caught on the dipstick and pulled it out of it's connector. It is a single wire that comes out of the fuse box and goes into the wiring harness to the fuel rails, the COPS and the alternator (with a connector in the middle). I stuck the wire back into it's connector though I don't know if that is good enough. It was something I was going to replace once I got everything back together. I'm not that great at diagnosing problems so any help would me much appreciated.
