1 - 5 of 5 Posts
This is a Garrett GT42 with a precision 76mm compressor wheel. It has a 74-82mm Turbine wheel. T4 housing with a 1.15 AR. The compressor housing is Powder coated metalic grey. I just had this turbo freshened/rebuilt. I have put about 60+ miles on it since the rebuild so it is still fresh. The turbo is on my car and if you are interested in it I will take you for a ride to show everything runs great. If you are local Dallas/Ft Worth. The reason I'm selling is I'm buying a bigger turbo. PM me if interested.
$750 plus shipping
What kind of power did you make with this?
800rwhp thru a TH400 with stock heads and cams around 23lbs of boost. Thru a 6spd it would be around 900+ It could probably make more but I never turned it up. I was out of Fuel pump.
1 - 5 of 5 Posts
