Supermod SB that's hurt.
#6 cylinder was down on compression (120) the rest were 150-165. Was not burning oil. The block is .030 over! Heads are stock 03's fully assembled w/ stock cams, and have had one five angle valve job. No tick. Heads have 55K on them. I think they have about 37k since the valve job. SB also has about 37k on it.
Right now it sits as a long block. Heads were pulled to look at the pistons/cylinder walls, then put back on lose.
Asking 2000 for everything.
Engine is at:
Dyno Tuned Performance, Inc. in
Chesapeake, VA.
Thanks
Discussion Starter · #2 ·
To the top..
I'll take 800 for the heads fully assembled w/ stock cams if you pay shipping.
Ok, I'll take 700 for the heads, and 750 for the short block.
