First off, I'm new to the forum and thought I'd introduce myself here. I've been a long time mustang fan but was always with pushrod motors, untill recently. Now I'm fixing to be the proud owner of a 98 V6 car with full bullitt swap! Everything from interior to drivetrain, suspension, brakes, electronics, etc.....
Now with that being said...... I've run across a deal on a Modmax 5.1 stroker shortbloc(H-beam Rods, Manley 7cc pistons) MV performance stage 3 heads and cams along with a vortech V1 set up for 14psi. Now my question is..... What all support mods are required for a motor of this nature? I plan on running my bullitt intake set up as what I have read has been pretty good..... But I know the fuel system is gonna need alot of attn. the car's chassis is ready to go.... Weld in subframe connectors, 31spline Moser, upper/lower control arms and such..... Along with a Tremec w/ king cobra 11".
I've been reading up on the dbl pump billet fuel hats to run dual pumps(I've never messed with anything of this magnitude as my other cars in the past were all bolt on stuff) would all new fuel lines be needed? Supply and return? Upgraded fuel rails?
Thank for you guys help and please bear with me as this is my first Mod motor experience
