1 - 2 of 2 Posts
Would like to know if anyone is running this combo of flat top pistons with 38cc trick flow heads as well as a large cam info on valve reliefs and compression ratio as well as fuel requirements. I am aware it'll need at least race fuel also that it will need valve reliefs just any specifics from someone's build would be great I could stress myself and calculate the compression ratio but figured maybe someone could save me from going to that length.
http://www.csgnetwork.com/compcalc.html
bore: 3.552
stroke: 3.543
head gasket: 3.63
compressed head gasket thickness: 0.036
combustion chamber volume: 38
head cc: 0 (no valve reiefs)
deck clearance: 0.008-0.012 (I used 0.010)
CR: 13.58
Use the link above if you want to use different bore (3.572-3.582) or add valve reliefs.
1 - 2 of 2 Posts
