1 - 5 of 5 Posts
1) is there a sure-fire way to know what crank bolt pattern i have without actually removing the transmission?
2) what is the correct balance to get?
for reference, my car was built 5/01 and has the 3650 5spd transmission.
thanks,
-Mike
edit. i found out the info i needed. i have a 6 bolt crank, and a zero balance f/w.
Hey Mike, I don't know if this applies to you, but the stock 01 Cobra clutch disc (3650) WILL NOT work w/ a Fidanza flywheel. Not sure if this is just the 8 bolt or the 6 bolt also:confused:
AutomaticWeapon said:
i hope ill be fine, i have a 11" Spec clutch. f/w and clutch should be here today.
-Mike
You're good to go. The spec will work fine. Just the stock 01 unit has these rivet things that drag on the flywheel
Good luck w/ the install:banggears
1 - 5 of 5 Posts
