Has anybody changed out there front control arm bushings for urethane type yet? Did it make that big of difference?
The '03 front control arm bushings are hydraulic fluid-filled and as such, polyurethane replacements may not be of considerable benefit if at all. That said, steel-sleeved Delrin bushings typically exhibit less deflection than polyurethane and are generally preferable.
Although #MMST-3 aluminum rack & pinion bushings are available, I would wait for the release of their '03-specific kit sometime later this year.
With regards to the FRPP bushings:
#1. Are the stock front control arm bushings for the '03 Cobra of equal, lesser or greater durometer than the FRPP Front Control Arm Bushing Kit #M-3070-G2 *and* are the FRPP Front Control Arm Bushing Kit #M-3070-G2 the proper replacement bushings for the '03 Cobra?
#2. Are the stock rack and pinion bushings for the '03 Cobra of equal, lesser or greater durometer than the FRPP Rack and Pinion Bushings #M-3716-G1 *and* are the FRPP Rack and Pinion Bushings #M-3716-G1 the proper replacement bushings for the '03 Cobra pinion brace (crossmember #4)?
#3. Are the FRPP Rack and Pinion Bushings bushings aluminum or polyurethane?
BTW, the reason I am asking about the FRPP bushings is because Ford Racing requires a dealer number for inquiries and the dealers that I had spoken to were practically clueless...
