I tested all the fuses in their holders and all tested good. I am going to replace all the fuses anyways because its a cheap and easy thing to do.
To be sure Im checking all the correct factory computer fuses, can anybody tell me exactly where all of the fuses are that make the cars fuel system work ? Or any fuses that are ultra cruicial in this situation ? I looked through the owners manual and checked what I thought pertained to the situation and they tested good with my test light.
Also, would the FRPS failure code trigger the fuel pumps to not turn on ? Like I said before, my SCT handheld does not have the ability to clear the codes ( its a 1st gen unit ) so Im going to unplug the battery for an hour and try that. After finding the codes, I did however re upload the tune and still a no start. I did not re check to see if it deleted the codes though.
What kind of voltage should I see at the input to the FPDM ?
What kind of voltage should I see at the output of the FPDM ?
What kind of Voltage should I see at the output of the BAPS ?
Im guessing the only way to check all of this is to do it right when the key is cycled so I'll need another set of hands.
