1 - 20 of 148 Posts
8-9 psi @490 corrected
triple pumps working [email protected]% duty cycle at 490 hp
tranny working great
converter working great
new turbo inlet pipe working great
HPX meter is a bad ass
THP kit working great
BBR stage 2 cams working great...holding strong and still making power at 6500...
Eric Brooks is working great too. He really knows what he is doing...
Only negative is turbo seems to be putting some oil out the exhaust at higher rpms....
MORE to come
also the E boost controller is kicking my ass trying to figure out how to make it come off the spring and go higher...
MORE to come
Congrats Dave. Glad to see that the car is up and running and Eric was able to do his thing on it. It's also very nice to see that the Triple Pump system is working our good for you as well. There's a lot more left in it so lets see ya turn it up!!
Jared
Eric truly is the best of the best. Congrats with your setup
It's probably your MMR motor pushing oil, not the turbo.
It's getting better................just made 530rwhp
I would look at those fuel pump duty cycles. Mine was only 35% at 600rwhp with the triple pump setup.
05 BOSS 302
Those duty cycle numbers are insanely awesome!!!
Dave what size restrictor do you have in the turbo oil line?
Earl
what tranny do you have? Could you post a copy of your graph real quick...need to look at a couple things
I don't have a copy of the graph. I run a 4R70W.
Whippled!
Cool beans--571rwhp at 13 psi. How much more in boost do you plan on going? What size turbo also, a 76mm?
Damn Dave, that's a pretty awesome setup you've got there.
Earl
That's always the first place I want to look when it comes to a modular having oil in the exhaust after the turbo issues.
Most people don't realize how much oil pressure they have and assume it's the same as a 5.0. (Since that's what everyone knows so well.)
Other than that, if the turbos have any sort of age on them, even if they've never been run, you run the risk of the seals going bad.
Well, we finished up about 45 mins ago. Spent most of the day figuring out the Eboost2 controller and the smoking.
I'll let Dave post up the numbers. :tip:
The duty cycle was around 60% tops. The low numbers posted before were incorrect.
The triple pump setup worked flawlessly. This was the first system I had tuned, and tuning it was as easy as the GT500 pumps. With an HPX sensor and the MAFia on 2, we never got higher than around 820 A/D counts on the MAF. This is in a 3" pipe, in blow thru.
Dave's transmission setup is top notch, and looks awesome.
I have a couple vids of the dyno runs I will post once I get them off the camera.
EB
1 - 20 of 148 Posts
