... My motor was rebuilt 3 yrs ago and has only about 6k on it but the builder set it up at 8.2:1 compression which I feel is way to low. I was thinking of going turbo because it will make much more controllable power ... I thought of dropping the engine and bumping the compression to 10:1 and see how it does. I could make more power with less boost and I bet it would be an animal.
Any thoughts?...
BlownBlu97,
If your comment about making more controllable power implies you have uncontrollable power right now then raising compression, as you suggest at the end of the post, with a twin screw will only aggravate an already troubling problem.
Higher compression on a turbo and higher compression on a twin screw do different things to the engine. Because the twin screw sees boost immediately and the turbo sees boost later in the power curve the twin screw loads all internals as hard or harder for a longer period of time. That means increased susceptibility to detonation and a significantly decreased safe operating window for boost, timing and fuel. Smaller mistakes will have bigger price tags.
While the engines can be run at higher compression ratios and reduced timing you are decidedly narrowing the elbow room you have available in the event of a whoops. If you are not racing the car competitively or using a turbo you may end up paying a higher price than you thought for the higher compression when something goes bump in the dark.
All of this doesn't mean don't do it but it does mean go in with your eyes wide open and pay attention to the details all the time not just during the selection / build process and don't bite off more than you can chew. BTW if you run ethanol, the anti knock qualities allow much higher compression and you surrender nothing in terms of safe operating window. You will however surrender gas mileage.
