Hi Guys.
First off this forum is the best for the 03 guys out on the edge, so I will ask here.
Where the hell can I get hold of Goodyear Gatorback belts in Sizes 4080780, 4080797, and 4080805?
Currently I have a 3.1 upper, a 2lb lower Metco setup with the lower idler pulley on the upper hole for good lower belt wrap and most likely I want to add the Billetflow 3 Idler upper pulley billet max belt wrap system using a pair of 100MM pulleys and a 90 MM pulley.
I figure I need the 4080797 belt for this setup, but if anyone has experience otherwise, please cherp in!
If anyone can help with a good source for belts, I sure appreciate it.
Mike69440
2003 Sonic Blue Mustang Cobra Coupe.
(Tucked away safe for winter)
Mods:
Holley 222-1 Air Filter
170 Deg Thermostat.
MM full length subs
QMP 3" 304 S/S exhaust With Cats
http://www.svtperformance.com/forums/showthread.php?threadid=24309&highlight=QMP+Exhaust
Amazon Diablo 2 program w/ single burn street Chip
Amazon/ Razor 3.10 upper pulley
Gatorback belt # 4080745
Royal Purple Lubes Everywhere
Water Wetter in Intercooler
BilletFlow Throttle Body
http://www.svtperformance.com/forums/showthread.phpthreadid=25834
Metco #2 lb & 4 lb lower pulley kit (Post Photos Later)
Reinforcing the Rear Seat delete kit for a kind of sweet big Retie/lab mix. (Post Photos Later with doggie installed)
Amazon Stage 1 Filter kit
Amazon Diablo 2 program race/street Chip
Denso Iridium plugs IT-20's
Autozone carries GY GB belts......cheap too.
--Joe
The obvious answers.
AutoZONE, NAPA etc. local supply companies all carry belts but I have not been abelt to locate sizes in Sizes 4080780, 4080797, and 4080805!
I am specifically looking for these sizes or close to it in alternates to the Goodyear GB's.
Thanks
Mike
It's tough, I wound up going to Gates for availability. So. Fla. Pulley has a big selection, I don't know his pricing?
