1 - 6 of 6 Posts
Or a mix or anything other than straight antifreeze. It's seems like the antifreeze is useless at the track. I would think Ice water would work good. And if your pump was running wouldn't that cool the intercooler down at the track faster? Or water and water wetter, then add Ice.
I believe Pete has a setup like that..
Also intercooler gets more fluid with his setup..
jim v.
The factory tank will not work for ice, Way too small ,You could only put a cup of ice in there, Not worth it , My kit holds 1.5 gallons, nitro Water wetter fomes up NG
You'll get some nasty slime in there if you do. The Lightning guys found that out. Lots of questions and ideas can be answered/found on the big Lightning boards. www.nloc.com is one and www.f150online.com L forum is another.
Not to disrupt the thread, but does Redline's Water Wetter foam. I have it but haven't used it yet. Thanks
It should not foam - it has silicone additives to prevent foaming - like Digel.
1 - 6 of 6 Posts
