1 - 2 of 2 Posts
I keep getting Errors. Below is what is going on when trying to load my file on my X4. I am using a .mtf file I had built.
Anyone have any suggestions? I have my car ready and want to try starting it with my new ID1000's and other items.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Management.ManagementException: Invalid query
at System.Management.ManagementException.ThrowWithExtendedInfo(ManagementStatus errorCode)
at System.Management.ManagementObjectCollection.ManagementObjectEnumerator.MoveNext()
at Sct.Mako.Mako.SearchForDevicePid()
at Sct.Mako.Mako.menuFileWriteiTSXBinFile(String deviceNameString)
at Sct.Mako.Mako.buttonProgramX4_Activate(Object sender, EventArgs e)
at TD.SandBar.ToolbarItemBase.OnActivate()
at TD.SandBar.ButtonItemBase.OnActivate()
at TD.SandBar.xf92605a24a69622a.x0ef5a9135fb0040c(TopLevelMenuItemBase xccb63ca5f63dc470, Boolean x674341222c6bbaba, Boolean x37b4525011735d95, Point x13d4cb8d1bd20347)
at TD.SandBar.TopLevelMenuItemBase.Show(Boolean select)
at TD.SandBar.TopLevelMenuItemBase.Show()
at TD.SandBar.ToolBar.OnItemPush(ToolbarItemBase item, Point position)
at TD.SandBar.ToolBar.OnMouseDown(MouseEventArgs e)
at TD.SandBar.MenuBar.OnMouseDown(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseDown(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at TD.SandBar.ToolBar.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.7.2101.1 built by: NET47REL1LAST
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
Mako
Assembly Version: 3.4.17010.2
Win32 Version: 3.4.17010.02
CodeBase: file:///C:/Program%20Files%20(x86)/SCT/Advantage%20III/Mako.exe
Win32 Version: 4.7.2053.0 built by: NET47REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Management
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
System.Data.SQLite
Assembly Version: 1.0.79.0
Win32 Version: n/a
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.Data.SQLite/v4.0_1.0.79.0__db937bc2d44ff139/System.Data.SQLite.dll
System.Data
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
System.Transactions
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.Transactions/v4.0_4.0.0.0__b77a5c561934e089/System.Transactions.dll
Sct.Common
Assembly Version: 0.0.0.0
Win32 Version: n/a
CodeBase: file:///C:/Program%20Files%20(x86)/SCT/Advantage%20III/Sct.Common.DLL
SandDock
Assembly Version: 1.0.6.1
Win32 Version: 1.0.6.1
CodeBase: file:///C:/Program%20Files%20(x86)/SCT/Advantage%20III/SandDock.DLL
System.Numerics
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.EnterpriseServices
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.EnterpriseServices/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
Accessibility
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
SandBar
Assembly Version: 1.4.2.1
Win32 Version: 1.4.2.1
CodeBase: file:///C:/Program%20Files%20(x86)/SCT/Advantage%20III/SandBar.DLL
Interop.XceedStreamingCompressionLib
Assembly Version: 1.1.0.0
Win32 Version: 1.1.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/SCT/Advantage%20III/Interop.XceedStreamingCompressionLib.DLL
Ionic.Zip
Assembly Version: 1.9.1.5
Win32 Version: n/a
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/Ionic.Zip/v4.0_1.9.1.5__edbe51ad942a3f5c/Ionic.Zip.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Discussion Starter · #2 ·
Turned out I restarted my computer twice reopened the program and all worked so I have no idea what the error is.
1 - 2 of 2 Posts
