Having to replace a couple valves on my 2000 Lightning.
Ended up buying the larger Mod Max intake/exhaust valves and doing both heads while I am at it. Does anyone have a kit with all the gaskets needed?? I was also wondering does someone make a better valve that will work with the stock retainers?? I do not want to spend a fortune but I would liek to put the heads back on there and not have to worry about them. Any advice would be helpful.
Nuke
Steeda sells a head changing kit for the 4.6l for like 100.00 bills. I don't know if it will work with a 5.4 though.
I run the Mod Max vlaves in mine and installed them myself with the help of lapping compound.:D
