1 - 2 of 2 Posts
Does the kit come with wiring to run the fans and the factory intercooler pump at anytime and will this kit work good enough with my new set up on the street or should I look into getting a bigger heat exchanger or put a cooler box in. New set up I discussed with you was the 6lb lower/2.80upper and idler.
Tommy :confused:
1 - 2 of 2 Posts
