1 - 11 of 11 Posts
I have a great opportunity to buy a rear end off a 2000 GT real real cheap. I told the guy I wanted the upper & lower control arms, brakes, shocks, springs, brakes lines, emergency brake cable. What else will I need to make this rear end go in without any problems. I have not yet found out if the car has traction control, will this be a problem? I hope someone that has done the rear end swap will please reply and help me so I can get this rear end on my 03 Cobra ASAP. If I have left out any parts I will need please let me know so I can take them off when I go get the rear end.
If some of you guys that have already installed the straight axle rear end can list any type of problems you encountered.
Thanks Stlblack03 for the more than informative info. Things are looking better and better. All I need is for the guy to back out of the deal he already made with me for the straight axle rear. Tomorrow we'll find out if he'll go threw with it ( am robbing the guy). Keep everyone informed after it's on.
Call Richard Lelsz at Strictly Performance--713-910-0111...he will help with any questions....if he is not available you can talk to Greg...Good Luck Man!
Ken
Better double check your driveshaft length.
I have a Viper T-56 in mine so obviously i have a different driveshaft,but i was told that the cobra and Gt cars use different length driveshafts.
Also i didnt use the live axle brake lines,i used the existing cobra lines,however i had to swap sides with the lines.
reason is clear once you try to bolt the existing lines to the GT calipers.
You won't need the e-brake cables but you will need the bumper and attaching parts that goes above the pumkin. The driveshaft may present a problem. With the earlier IRS cars all you needed was a driveshaft from a GT because the trannys were the same length. I believe the 6 speeds are longer so a GT driveshaft won't work. If the rear does not have TC then I personally would pass on it and find one that does, not so much for the TC but the ABS capability.
A thought just came to me about the driveshaft length. The '99-'01 IRS shafts were shorter than the GT's. If the '03's are shorter still than maybe a shaft from a '99-'01 Cobra will work in an '03 with a solid rear.
re:
wow I am confused are you getting a solid axel loosing the irs?
if so the gt rears from 96+ will all directly fit no problems at all. just need new exhaust ot get over the axels
Night Trains Daddy
Actually 99+ rears are the only ones that fit properly all the others are 3/4" shorter on each side.
The Stock DS will work but you need the yoke? (can't think of the proper name) The part that the DS bolts to??? Off the IRS. This is what I've been told by a couple people who have done it on 03's.
PM Charlez03 on this board...he has done it
i wonder if you used an older rear(94-98) you could probably use a rim with a huge dish, and less backspacing, which would look really good.
1 - 11 of 11 Posts
