I've got a ported Eaton with bolt ons, and I'm ready for more traction and reliability when I go to a drag race 90 miles away, meaning I'll be driving to and from the track and also running the car at the track, so I need the reliability of a solid axle rear.
I plan to continue running my 28" tall M&H drag radials on my 10.5" Cobra wheels, so I'm definitely going to step up to 4.10 rear gears, but other parts have me a bit baffled.
Control arms I know I won't be reusing the stock ones coming off an 02 GT, so I'm wondering if I need adjustable uppers and lowers or will a solid aftermarket non adjustable be OK, I know I can get the BBK of UPR non adjustables for under 200, or is this whwere I should step up to adjustable ones for another 100-200$ The granatelli's or UMI's look like nice ones, but expensive?
Rear diff I can go with a simple Ford tracion lock from jeggs for around 260$, but again would a Detroit True-trac, or an Auburn pro series be worh an extra 200 bones? I kind of like the Idea of the True-trac because it doesn't have any clutches that wear out and need replacing, but I'm also a big fan of money, so the traction lock from ford racing might be the ticket???
Springs I can't seem to find alot of options with springs other than the stock ones that I could re-use from the rearend doner car, or I see Eibach sells a launch set for around 250$. I've also read and heard of people using four cylinder fox mustang springs, but I'm not sure if that was aimed at the front suspension moreso than the rear? Again if the free springs I'll be acquiring with the rear will serve me fine, I'll save a couple hundred dollars and re-use them babies.
Shocks The price seems to go up quickly with double adjustable shocks, so I'd like to spend under 200$ on a decent set of single adjustables instead of 400-600$ double adjustables I've seen advertised in magazines, unless it's really necessary?
I'd appreciate any experience with these parts, the car isn't a daily driver, but I do need it to be street friendly and tough enough to abuse a bit at a track. I also need to drive it home from the track wich is out of town since there isn't a local drag track of any sorts. On a side note, I plan on using non "C" clip 31 spline axles from moser for a bit more durability and whatever the difference is with the abs system, I'll be getting that too. Any helpful advice would be great.
