1 - 14 of 14 Posts
Ok, I'm out in California. I'm running a Kenne Bell at 15 pounds with no BAP with the 55 pound injectors with 91 octane. I threw a rich bank 1 code after tuning. I made 557 RWHP with only 485 RWTQ. I'm wondering why I got such a low torque number? I know my car is running rich at about 1500-2000 but why? Is this a tuning issue? Bad Injectors? HELP!!!!
Pardon the question but what is a rich bank 1 code? I have the same set up and made 511 rwhp and 464 torque. I think your numbers are good.
Your TQ is lower than mine and I thought mine was low. I'm using stock injectors also. Whats your exhaust set-up?
03snake and vindication:
What are your a/f ratios like? My hp is much lower than yours but my a/r ratio is very reach at 10.0:1
mine is there in the early RPMs. 10. goes up to about 11.5 from there. I'm running Bassani catback with Straight H.
the rich code has nothing to do with WOT Driving, it's all part throttle adaptive stuff. It just means the air meter transfer function is over 25% too high in your part throttle/cruising range. Won't have any affect on your WOT numbers, only the a/f from the dyno pulls will show that.
Brian
My A/F never goes below 11.7:1, starts out in the high 12's...
You're starts out at 10:1? Mine starts out in the high 12's, would this be the difference in 20ftlbs of TQ since the majority of our TQ is down low.......
I had the same issue. I had the 15 psi pulley and made 546 rwhp /484 tq. I added a 17 psi pulley and both numbers went down. I took the car to Razor's Edge Motorsports in Margate and spent a week and a half on the car tuning.
First, they saw that I was getting a drop in fuel pressure at WOT. So I added a KB BAP. That solved the fuel pressure issue. They then saw that I was running out of injector with the stock 39# injectors. I installed 55#'s. With a VERY conservative tune, the car made 600 torque on a Mustang Dynamometer. The numbers in my sig were done a day later on a DynoJet. The car runs awesome now!
1 - 14 of 14 Posts
