1 - 5 of 5 Posts
I've run into a snag with my 8 rib setup.I have the upgraded pulley bracket(large idle) for my Vortech.The 2 pulley's that have been sent dont work.They stick out to far and wont line up with the blower pulley.Do ya'll have this setup?If so,were did you get a pulley with enough set back to line up and clear the alt..I've tried 2 different kinds with no luck.If yall dont have an answer,guess Im fabing a different bracket.Ever notice how freakin nothing bolts on these cars?Every time I turn around Im making something or having something made.:rolleyes:
Tim
The GT bracket is different I am sure, so I am not sure which idler you are talkiing about. The Vortech idler or the Ford idler? You can call me at the house if you want, I will be here. 229-388-9449
Chad
ATI made my pulleys for 8 rib setup on my 99GT..
jim v.
Thanks Jimmy..Hey Chad,the stock GT idler worked in the place of the vortech pulley.After talking to you it dawned on me to use it..:D
Tim
That is good Tim, sometimes it helps to step back and talk to someone just to hash out ideas and thoughts!!
Chad
1 - 5 of 5 Posts
