1 - 15 of 15 Posts
I am uninstalling my Saleen gauge pod... How do I fix the holes in the dash? Can I replace the Dash? Is there a leather cover kit to cover it with?
Sold my blower/accessories.
Well, see if you can trade your dash for theirs ? If it is the same color,and save them from cutting their dash. Just a thought .
I was wanting someone to chime in that had replaced theirs before? I'm not sure how you'd go about getting it out of the car?
Removal and Installation
CAUTION: Electronic modules are sensitive to static electrical charges. If exposed to these charges, damage may result.
  1. Depower the supplemental restraint system (SRS).
  2. Remove the floor console.
  3. Remove the 2 scuff plates.
  4. Remove the 2 A-pillar lower trim panels.
  5. NOTE: On the coupe, install the front locating hook, then snap the A-pillar trim panel in place working rearward. Remove the 2 A-pillar trim panels.
  6. Remove the instrument cluster.
  7. CAUTION: Do not allow the steering column to rotate while the steering column shaft is disconnected or damage to the clockspring can result. If there is evidence that the steering column shaft has rotated, the clockspring must be removed and recentered. Secure the steering wheel, remove and discard the bolt, and separate the steering column shaft from the steering column.
    • To install, tighten to 25 Nm (18 lb-ft) .
  1. Remove the 2 screws and the steering column reinforcement cover.
    • Disconnect the 2 electrical connectors
  1. On the LH side disconnect the instrument panel bulkhead electrical connector and remove the instrument panel support bolt.
    • To install, tighten to 20 Nm (15 lb-ft) .
  1. On the RH side disconnect antenna in-line connector and the 4 instrument panel harness electrical connectors.
  2. Remove the 2 instrument panel center support screws.
  3. Remove the 3 instrument panel center support bolts.
  1. Through the instrument cluster opening, loosen the instrument panel cowl top bracket nut.
    • Tighten to 9 Nm (80 lb-in) .
  1. Remove the 2 instrument panel lower support bolts.
    • To install, tighten to 9 Nm (80 lb-in) .
  1. Remove the 2 instrument panel end panels.
  2. Remove the 4 instrument panel upper support bolts.
  1. Disconnect the RCM small connector.
  2. NOTE: Two technicians are necessary to carry out this step. Remove the instrument panel.
  3. To install, reverse the removal procedure.
Is this what you were looking for ??:dunno2:
What a nightmare....
If it were easy, children would be doing it LOL. Patience grasshopper .It looks worse than it really is .
Oh, just remember that you don't have to take all of it out that is in the picture I put up, it is just that is the only way I can show it. You are only taking the top part off.
Discussion Starter · #11 ·
You speak the truth... lol
The best I remember, you just have to take the 4 side bolts out, 2 on each side, and pull it loose , but I am getting older and tend to forget a lot LOL
Does that remove the entire dash or just the top?
If I could simply pull the top portion, that'd be sweet. I'd send it out to get covered in leather. :)
Take the 4 bolts off the side, and the top will come loose from the rest .
Im not sure if someone said this or not. I didnt read through the whole thread. Why dont you change your guages to different ones? Like oil, fuel pressure, etc. etc. etc. I think it will be more work than its worth to replace the dash. I would get the gauge you can still use.
1 - 15 of 15 Posts
