They are the lowest priced slicks around. So those are my two options. Which one would be better for my n/a 01 GT? I will be launching at 6k if it matters.
i'm sure since they are both slicks u will hook just the same on both, i used et streets and dumped it at 4500 and hooked great, watch your rear end though it might go...i say go with MT just because i have used them before, but i'm sure they both work the same
I've had MT ET Drags,and the Hoosier Quicktime DOT Pro,and I like the Hoosier better. they are only 26x9.5x15(and that's section width,not treadwidth like a slick),and they are handling my launch with the 3500 rpm convertor with no slippage. The DOT Pro also has a slightly stiffer construction,so the car doesn't squirm as much on the top end of the track.
JL
