1 - 8 of 8 Posts
Im seeing about 14psi and it falls off 2psi in higher rpm's. I have some slip though, need to go down about 1/2 inch on the belt 74.5 with 2.8 and 100mm idler, gettin some dust in the spokes.
Thats about what I'm seeing also.....
I am seeing a steady 13lbs with little to no drop off...the needle just pegs 13 psi. is this because I have the TB and plenum? I can't see my 2.93 putting down 1 less psi than a 2.80....
broke7 Wednesday we need to go on a run, you need to film my gauge during a 3rd gear pull, I am very curious now
On a 4th gear pull on the dyno you will see drop off.
In 4th under load you will actually see more boost and also more drop off.
Sonic, lemme know what time you are free. I am working mids this week, go in at 11pm.
My gage is tad off I think, my pointer with the car off sets below ZERO and ive seen my fair share of boost gages :p
we can pop mine out broke7 and see what your car does....
thats cool.
I was seein 14psi today maybe 13.
The charger has a real cool whine/whistle now at cruising speeds and part throttle with the tighter belt. I think my slip is gone finally.
1 - 8 of 8 Posts
