1 - 2 of 2 Posts
Hello all.....
I am in the throws of installing a Lincoln Mk8 engine in my fox body Mustang. How does the hydroboost brake master work and what parts are needed to set it up?
THank you!
I havn't heard of any problems so the hydraboost must be fine, just be sure to use the correct proportioning valve.
You will need the hydraboost unit, master cylinder, lines from the unit to the steering pump and according to the brake system you use, you may need either the hydra proportion valve or an aftermarket one. There is a slight mod to the firewall to mount the unit, and brake lines will need to be fitted. As far as the rod to the pedal, I am unsure what the guys are using.
1 - 2 of 2 Posts
