1 - 2 of 2 Posts
I just blew my third idler bearing in 2 months..Running Vortech S trim 16 lbs. boost with 8 rib pulley set up (DOHC/98Vert) The idler bearing I run is supplied by Vortech and is about 1/8" shorter than the 8 rib belt width. Does any one know of an after market Idler Bearing that will hold up?? Also shreds the serpentine belt at $47 a shot plus $60 for the bearing...:(
Discussion Starter · #2 ·
Idler Pulley/Cobra 8 rib
In case anyone is interested...Auto Specialists makes after market for just about anythig including the idler pulley(with HI-RPM bearings and the width to match the 8 rib belt) Ph. 281-261-5811..ask for Lee:blob
1 - 2 of 2 Posts
