1 - 12 of 12 Posts
Well, Here is my 02 GT I have been working on, it has 4:10's SVO shorties, with BBK off road X pipe, stock Mufflers, Bullitt intake with BBK Throttle body, Vortech V2 Polished S. Trim 13 PSI, Anderson Ford Power Pipe, 42 Pound Injectors, 90 MM LM. I just added the air to air inner cooler it came out real well and so far I am seeing out side air temp, which is very good, I want to install BBK LTH, but they don't make them for a GT with a 4R70W, but I think I can massage the ones for a standard and make them fit, I want to add Flow Master mufflers and a PI 3000 stall, I will get it on the dyno and post the numbers, later this week.
AWESOME
Nice setup Dennis...very well planned out street animal..
i like it. :D
jim v.
makes my car look like a turd...NICE JOB! BTW its inter-cooler and if you really wanted to get technical..its really an after-cooler. Thank you, good day!
The cooler was made by a compamy that has gone out of buisness TDC but I can still get them from another source I guess I will look into making this kit avaialble.
Dennis
Dennis
Dennis..TURBO DRIVEN CONCEPTS Scott Sussman?is that the TDC you are referring to? If so i didn't know they went out of buisness..
Jim V.
Wow, that IC is really nice. Looks just like my Paxton IC except the inlet and outlet pipes are not underneath the IC. God I hate that too. How much do you think those would cost to buy????
1 - 12 of 12 Posts
