I am attempting to install my Accufab 70 mm throttle body and I can't get the bottom throttle cable connector off the stock unit...the one with the plastic shroud. Is there a trick to this? It is really on there, and I am afraid to force it as I do not know which way to put pressure.
Do I pull toward the firewall, up, down? Can I just put a flathead in between it and the linkage and twist?
Any help or suggestions would be great as I would like to get this done.
Also, how do I set the the tps? Some say I need a special tool, and others say that there is nothing to it. Any help on this would also be a great benefit to me.
~Darren
Discussion Starter · #2 ·
Bump -- someone must have changed their throttle body.
~Darren
Just had my TB off last weekend and the lower cable just snaps on(down) So just push it up to pop it off
It will NOT budge...here is a shot with an arrow pointing at the cable I need off. Then I will deal with the TPS.
Any more suggestions gents?
~Darren
